JD Gauge Set AM453-T
David Witkege
07-03-2003 10:09:52
Mr. Clooney, Scott Carlson at the JD Collectors' Parts Line suggested I forward my question to you. I am rebuilding the hydraulics on my '57 420W, ser#128,406. To set the 2-stage check valves on the Dual Touch-O-Matic system, the AM453-T guage set consists of pin"A" and plug"B". I believe the pin is 7/16" in diam. and the plug is the size of the control valve rod. The problem is the length of plug B, which gives me my reference measurement against the back face of the control valve body casting. If I knew that dimension, I'd be home free. Can you help? Thanks, David
David Witkege to Mr Cloon
07-09-2003 06:51:41
 Re: JD Gauge Set AM453-T in reply to David Witkege, 07-03-2003 10:09:52
