JD 720 w/broken conn. rod
Matt
07-03-2003 09:18:23
I have a JD720 Diesel Standard with a broken connecting rod. Questioning if this should be repaired or the tractor just sold as is or for parts. I am no mechanic and want a running tractor. This tractor hasnt been run in 6 years, so I assume the piston would also be frozen on that side. I can get the crank to turn half a rev and then it catches due to the broken rod. Otherwise, the tractor is in decent shape, needs some minor repairs to get operational. Just wondering what it would be worth in this condition, and what to expect if repairing the rod. The pony is fine, no PS, sheetmetal is good, rubber fair, paint faded. Your thoughts???
Ken Talatzko
07-03-2003 21:45:18
 Re: JD 720 w/broken conn. rod in reply to Matt, 07-03-2003 09:18:23
Matt,
Please Email me....I have some specific ideas for you to consider. Thanks, Ken
Ken Talatzko
07-04-2003 06:04:56
 Re: Re: JD 720 w/broken conn. rod in reply to Ken Talatzko, 07-03-2003 21:45:18
Sorry, Here's my Email [email protected]
dwm
07-03-2003 18:02:07
Matt,
I don't know much about the worth, but do know you would not have any trouble selling as is. If you plan on paying someone else to fix it, you could get into some $$. You could just replace the rod on that side, but once in it that deep, I'd want to check the other rod for cracks. Also the crankcase, oil lines, crank journals, etc. for damage. Since this is a working tractor, if you had it fixed right, you now know what you have. If you sold it and and bought something else used, you could be back in this situation again because you never know for sure. Just my opinion, but I'd find someone I trusted and fix it. Good luck with it.
Ben.So.Tex
07-03-2003 17:14:10
Where are you located. send E mail Thanks
Matt
07-04-2003 14:20:46
 Re: Re: JD 720 w/broken conn. rod in reply to Ben.So.Tex, 07-03-2003 17:14:10
Ben, says I cant email you because you you have hidden your email address. Need your email address.
jason r
07-03-2003 12:45:45
where are you located and how much would you want for it as it sits? email me if you are wanting to get rid of it withour repairing it....
