Breaking-in oil question
Rich
01-14-2004 05:42:33
Will be starting the JD 520 after rebuilding the engine. Bored 0.045 over, new pistons and rings. The operator's manual said when new this tractor was shipped with special "break-in oil" and to run that for 20 hours before changing. What's a good breaking-in oil to use and where can it be purchased ? What breaking in methods have you used with good results ? Thank you, Rich
JC
01-14-2004 18:50:30
 Re: Breaking-in oil question in reply to Rich, 01-14-2004 05:42:33
There are many opinions on this subject. The little green card that came with a set of piston rings I bought recently from JD for my "D" says to do the following:
-Install New oil filter
-fill with 10W oil
-run at slow idle for 10 minutes
-run at fast idle for 10 minutes
-operate at no more than 1/2 to 3/4 throttle for 20 hours
-replace oil filter and oil after the 20 hour break-in.
One fellow recommeded turning the engine over with another tractor using the belt pulleys to slowly break it in.
F-I-T
01-14-2004 07:12:48
In my '70'D (bored with new pistons), and the VAC (honed with rings only), I used the JD break-in oil and I was very pleased with the results. However, I probably had just as much luck using 20W non-detergent which I used for all those years before they began marketing break-in oils.
Frnak-in-LA
Stan - Florida
01-14-2004 08:45:37
 Re: Re: Breaking-in oil question in reply to F-I-T, 01-14-2004 07:12:48
I see that "Frnak" guy is doing your posting for you again - LOL. Don't let the fruits and nuts out there get you!
Stan
DaveH 50
01-14-2004 17:31:14
 Re: Re: Re: Breaking-in oil question in reply to Stan - Florida, 01-14-2004 08:45:37
Rich,
Your Deere dealer should carry the break in oil in gallon jugs - part #TY22041.
Stan, I'm a little concerned about this F-I-T guy. One day he thinks he is Frank and the next day he's Frnak. With some of his lye gravy type concoctions I'm thinking maybe he's really Frank-in-stein! :)
Dave
Stan - Florida
01-14-2004 19:10:38
 Re: Re: Re: Re: Breaking-in oil question in reply to DaveH 50, 01-14-2004 17:31:14
Dave,
You have every right to be concerned. Even worse than Frank-in-Stein might be if he went to Germany - that could be wurst. - he might become Frankfarter.
Stan
T-F-I
01-14-2004 18:15:50
No worries there.....I am BEER-in-Stein!!!!!
Frnak-ni-AL
F-T-I
01-14-2004 08:50:21
I just tyop fastre thna I shuold !
aH!
Frnak
MIKE HANLEY
01-14-2004 06:00:46
Probably will be many pet ways to do this. Many operator manuels say to run light loads for a day or two. Such as if you could plow in 4th gear, plow for a couple of days in 3th gear. The last two engines we had overhauled at the JD dearler, to set the rings they dino it, lugging it then backing off, lugging it and then backing off again, etc. And of course, they put in JD brake-in oil. From that point on we use FARM OYL brand GP-3, 30# in eveything we have except the cat and truck. We use the GP-3 30# in the PTO's and the HYDS of 430 630, 730D's and the CJ-2A JEEP. That way we only have to have one oil on the place and there is no question as to what oil goes where.
