Mt heating up
jim
07-02-2003 15:54:27
Hi Im new to the J deeres, have an MT that heats up real quick, have had head mag fluxed and planed no cracks new head gasket, had radiator checked out is in good condition, no air bubbles in rad, shoot it with heat gun the head is hot (well over 190) the block is cool and rad is cool, seems to not be circulating, what should I try now? Thanks
whizzer
07-03-2003 17:08:42
 Re: mt heating up in reply to jim, 07-02-2003 15:54:27
Use plain water in the summer. Your problem will go away.
Deere One
07-03-2003 12:56:20
you didn't say the year or serial number of your MT, but i suspect it is one of the older ones. Deere had a problem with the location of the heat sending unit in the earlier tractors. It was in the top of the water manifold, where the water is the hottest. Later, they moved it to the back of the block for a more even temp. reading. If the bottom hose and block feel cool, don't be upset. Mine runs at 220, and you can hold your hand on the bottom hose. Check your year and location of the sending unit. E-mail if you need more info.
Clooney
07-03-2003 05:09:35
Jim, you sound normal for a thermo-siphon cooling system. The water won't circulate UNTIL it heats up so they do heat the water in the engine quickly.
~The block WILL be cool as there isn't any low water jacket in the M. The bottom of the radiator & radiator pipe should also be cool as that means the radiator is doing it's job & removing the heat from the coolant.
~The water moves slowly in a thermo-siphon cooling system so the radiator pretty well removes all the heat [at least while not working]...Take it out & run it under load for a while & see if the bottom of the radiator gets hotter..
Bus Driver
07-03-2003 04:49:40
The thermosiphon systems depend on a continuous loop of coolant for circulation. If coolant level drops to the point that it does not connect at the top of the radiator, then there will be no circulation. That may not be your situation, but regular checking of coolant level is critical.
Richard
07-02-2003 16:24:33
Sounds normal to me. The thermal syphon cooled critters run hot. Mine pops along at 200+ on a hot summer day. As long as it doesn't boil over, you probably have a happy tractor.
