G valve train settings?
Jack
07-02-2003 13:48:17
Have any of you tried different valve lash settings on a styled G?I have heard of several different settings and have tried a few but have not hooked to a dyno to see the difference.I was wondering where the most power could be made at what settings.Mine is not a flat head.Thanks
Steve - IN
07-03-2003 05:53:45
 Re: G valve train settings? in reply to Jack, 07-02-2003 13:48:17
Jack,
Changing valve lash or cam timing basically just shifts power from low to high RPM or vice versa, with no real net gain across the board.
Tightening the lash will increase the top end power while loosening it will increase bottom end power. Be careful how far you go either way.
Jack
07-03-2003 07:33:27
 Re: Re: G valve train settings? in reply to Steve - IN, 07-03-2003 05:53:45
If I wanted it to hang on and lug what would I set them on?Right now they are set on,intake .020 and exaust .022.She seems to lug very well but I was needing just a little more.Thanks for the info.
Steve - IN
07-03-2003 17:54:43
 Re: Re: Re: G valve train settings? in reply to Jack, 07-03-2003 07:33:27
third party image
Jack,
Here's an idea of what can be done with changes in duration by advancing or retarding a cam thru chaning the valve lash. This torque curve graph is from changing duration by 20 degrees. The most you can hope for by changing lash setting is 4 or 5 degrees -- but the relative curves of more or less lash is the same.
This is a auto engine, the green curve is with less duration (the effect you get by increasing the clearance between rocker arm and valve top). You can see you don't get any greater torque levels, you just shift where it happens in the RPM range. So if you want it to lug --have more torque -- at 300 to 500 RPM on the G, you starting increasing the lash. You'll get more results from changing the intake side than the exhaust side. If you're at .020 on intake, I'd go to at least .022 you have on the exhaust, then see what happens at .023 and .024, etc. There's a point when you might be in danger of falling of the cam ramp, and also with too much lash there's just not enough fuel flowing in. So change in small increments - be careful. Sure helps to have a dyno when you're doing this kind of stuff.
