Coil wires on a wico xh mag.
Terry
07-02-2003 07:14:13
Can anyone tell me "Or have a pic "where the coil wires go in the mag of a wico xh magneto.There is one that is bare and the other is black plastic coated.
John T
07-02-2003 11:44:19
 Re: Coil wires on a wico xh mag. in reply to Terry, 07-02-2003 07:14:13
Terry, on some I have seen or the newer ones I purchased from Roberts Carb Repair, they will only fit one way and thats the right way, assuming you have the correct and original mounting attachment screws and use them in the right eyelets according to their different sizes. Thats cuz the diameter of the coil leads lil round eyelet terminals only allows the bigger mount to fit inside the bigger terminal, while the smaller one remaining is for the smaller screw. (seems like the big one was points and small one case ground, but Im not sure)
HOWEVER, if that dont work, on I think ALL I've ever seen, the bare looking thin shellaced smaller wire is the case ground, while the larger black heavier insulated wire is what attaches to the points terminal where the condensor also goes.
Hope this helps.
Good Luck n God Bless the USA
Clooney
07-02-2003 07:39:17
Terry, the plastic coated [insulated] wire goes to the points terminal screw [the same place the condenser connects] , the non covered wire(s) go to the mag case ground screw near the coil retaining clip.
