How rare is wide front on a B?
Rodney A. Johns
07-02-2003 06:25:17
Found a B with a wide front. Asking price to me seems high, but then I've never seen a B with a wide front. Cannot seem to find a place where I might find out how rare this is.
Could someone point me to a website that would have this information. Thanks for the help.
Dennis
07-02-2003 17:23:08
 Re: How rare is wide front on a B? in reply to Rodney A. Johnson, 07-02-2003 06:25:17
What year is the 'B' you are looking at?
Rodney A. Johnson
07-03-2003 06:26:56
 Re: Re: How rare is wide front on a B? in reply to Dennis, 07-02-2003 17:23:08
It is a '41. See my response to Jerry for other details if interested.
Dennis
07-03-2003 08:58:26
 Re: Re: Re: How rare is wide front on a B? in reply to Rodney A. Johnson, 07-03-2003 06:26:56
Rodney,
To see a photo of a factory wide front, go to the YT Tractor Photos and do a search for "John Deere BWH". The one that belongs to Bob Gauntt gives you a good look at a factory unit (the 'anteater' design). I'm not saying the tractor you are looking at is a BWH, which is quite unique, but that photo gives you something to compare to the tractor you are looking at.
Dennis
Rodney A. Johnson
07-03-2003 10:19:02
 Re: Re: Re: Re: How rare is wide front on a B? in reply to Dennis, 07-03-2003 08:58:26
Thanks for the information. Sadly my memory has faded too much to be sure if it is the same wide front or not...I'm thinking not, but...guess I need to get another look...and take a picture or two.
Would the serial number tag have BWH or just B? According to the photo you mentioned only 268 made over a number of years, so that would make the option more rare and probably would justify the price some....if it really is a BWH and not somebody trying to pawn it off as one.
Dennis
07-03-2003 11:33:38
 Re: Re: Re: Re: Re: How rare is wide front on a B? in reply to Rodney A. Johnson, 07-03-2003 10:19:02
Rodney,
I do not know if the tag will say 'BWH'. On my 1949 'BW', the tag does not say 'BW'. If the tractor has a factory wide front it might be either a 'BW' or 'BWH'. The 'BW' is not as scarce as the 'BWH', but certainly collectable still. The 'BWH' is a high-clearance tractor and would have longer rear axles and 40" (they might be 42", I can't say for sure) rear tires. Yes, you should take some photos and then share them on this board to get more assistance.
Dennis
Dennis
07-03-2003 08:39:54
Rodney,
The factory wide front on a '41 Model B would be of the 'anteater' design with a round tube cast main axle housing.
Dennis
Jerry C OK
07-02-2003 10:08:31
Depends, if it's factory or after market.Factory somewhat rare, aftermarket not to uncommon I have a 49 B with aftermarket (Swartz I think) don't think it adds to value
Rodney A. Johnson
07-02-2003 11:25:09
 Re: Re: How rare is wide front on a B? in reply to Jerry C OK , 07-02-2003 10:08:31
I think it is a factory wide front. If I remember correctly it is adjustable too. I recall one of the I&T manuals indicating there were two kinds...fixed and adjustable.
Jerry C
07-02-2003 11:39:11
 Re: Re: Re: How rare is wide front on a B? in reply to Rodney A. Johnson, 07-02-2003 11:25:09
May be, my Swartz is also adjustable, round tube.
Was a photo of my tractor in photos, might try a search to compare Jerry C
Rodney A. Johnson
07-03-2003 06:25:25
 Re: Re: Re: Re: How rare is wide front on a B? in reply to Jerry C, 07-02-2003 11:39:11
Your B looks a lot nicer than the one I saw. The wide front is not the same. But my mind is starting to get foggy so can't recall for sure but think the wide front was square like. Kinda like a solid I beam. The steering links were adjusted by sliding a clamp on a steel shaft to get proper toe in.
It does not have a powr trol, is a '41 model. Hand start with Wico (don't know if I got spelling right) mag.
At least one brake is sticky, and whole tractor couldn't have ever seen a day inside after it left the factory. No major dents or tears in metal. Everything looks all original. Supposedly runs, but have not heard it yet nor have I talked to the owner.
