JD H fuel tank
Aaron
07-02-2003 00:20:09
I am in the process of restoring my model H. The biggest problem I knew would be the fuel tank. I just took it off tonight, but I didn't know how large the problem had become. The size of the hole in the tank is about the size of your fist and has a small crack which runs along the seam. What is a average cost of another fuel tank? is it cheaper to fix the old one? What kind of price can i get on another fuel tank at a wrecker?
I also have a few small holes in the hood. How expensive is it to get them fixed? How do you fix them so the exterior of the hood is perfect after a new paint job?
Thanks for any help.
Frank M.
07-03-2003 11:44:41
 Re: JD H fuel tank in reply to Aaron, 07-02-2003 00:20:09
You might check with Sharp's or Lindstrom's for the tank. When I sandblasted the hood on my H I noticed a couple of pin holes appeared. I filled them with JB Weld and sanded it down. You'd never know they were there. Good luck with your project.
Frank M.
