Intake valve excessive heating
Jon
07-01-2003 12:55:51
After having my valves reground for the second time, the machinist commented that the intakes were blued from excessive heat. What would cause this? The cam and magneto timing are perfect.
Larry
07-01-2003 19:09:14
 Re: Intake valve excessive heating in reply to Jon, 07-01-2003 12:55:51
After having read your post, the thought occurs to me....based soley on a similiar comment made a couple of months ago by an automotive machinist working on a head of mine....I'm wondering if these guys typically find fault with the machinist that worked on it before them.
"who ever worked on this head had it all "fouled" up.... Makes me wonder.....
buickanddeere
07-01-2003 16:32:59
Lash too tight, seat too narrow, advanced cam timing, coolant passages full of corrosion, lean mixture and continous operation at 100% power?
Bob
07-01-2003 15:01:42
Did you ask the machinest his opinion on what would cause heating and subsequent "blueing" of the valves?
Clooney
07-01-2003 14:15:12
Jon, if it's just the intakes & not the exhaust valves [your problem is more common on exhaust valves] look for worn valve guides, tight valve lash, improper seat or valve face angle, weak valve springs, too thin valve edge, or leaking valves...
Robert
07-01-2003 13:47:52
I haven't heard that term before, but perhaps he's talking about the valve edges, which may become discolored if they're too thin, resulting in them getting hotter than normal?
Interesting, though. Maybe someone else will have other ideas.
