Mornin Dave, when you set that old mag timing impulse as you described, you were only setting the start timing, while the run time advance depended upon where you had the rear coupler lag angle set to. Now, if you want to use a timing light to tweak in the new distributor timing, you're going to have to make some degree marks on the flywheel, if it doesnt already have any. To use the Left Hand Impulse flywheel mark to time, measure the flywheels outer circumference and divide by 360 to get how many radial inches per degree, and then measure off and make marks on it at maybe 20, 25, 30 and 35 degrees etc. BTDC. The Left Hand Impulse on the flywheel at 3 o clock in line with that flat mark on the side of the tractor is when the left piston is at TDC (both on compression and power), so make the marks startign there as 0 degrees. There was a great deal of discussion on here a while back about the modern DC powered timing lights and settigns for 2, 4, 6 or 8 cylinder etc. engines to make them accurate on our 2 cylinders, but all I have is an old fashioned self powered type and it works fine and needs no adjusting. When its on the left plug wire, it lights when it fires and shows me on the flywheel advance marks where I'm timed at. As far as how much advance you can run, that depends upon the RPM, compression, fuel characteristics, valve dynamics and other variables. HOWEVER, as I have noted on here before, continued faster and faster timing advance is no fix or necessarily any help in horsepower gains (hurts if too fast). Its when you run extreme high RPM's (which our old JD's do not run at all) with high compression and high octane fuels etc. that advance becomes more important and critical, but in our old low RPM Deeres, too fast timing can cause more harm than good. Without knowing your RPM and compression and fuel etc., I still doubt that much any advance over 25 to 35 is what you end up at. If you have access to a dyno I would use it and then tweak the timing for the best results. If you get her too fast at starting, it can be tough on starter drive assemblys (engine wants to kick back badly), so maybe you need to look at the advance on that distributor and get inputs from pullers on how they tweak that in. To get full advantage of that ignition module, couple it with a high energy coil and run a wider plug gap for a wider, fatter (more surface area), hotter spark. Its high compression that requires more energy be discharged across the plug gap, but even at lower compression, a good hot high energy spark improves performance. Good Luck n let us know where you end up at. God Bless the USA John T Nordhoff
