JD H Lack of Power
Rick
06-30-2003 04:37:29
We have a 1950s H it has no power, it will idle fine.
i think the govenor is not working. how would we check the govenor. also looking for diagram for govenor. Thanks Rick
Dave K
06-30-2003 15:51:39
 Re: JD H Lack of Power in reply to Rick, 06-30-2003 04:37:29
Purchase the manual, it will tell you all the things you need to know.
Dave
Jon
07-01-2003 13:04:45
 Re: Re: JD H Lack of Power in reply to Dave K, 06-30-2003 15:51:39
First check the compression. Could be rings or valves leaking. Then check the spark and magneto timing. If your tractor will not hand start most likely these are the source of the problem. Once running the speed of the engine over comes the deficiencies of low compression and it idles pretty good. An owners manual will help point out these areas to check.
