John Deere Disc Update
Harry
06-29-2003 18:15:42
Larry, Mike A., Dan: I have a little more information for you to help me figure out what model disc I have. It is 7.5 feet wide and has 14" blades on it. The front and rear disc's hook together in an "X" fashion. It has rectangular weight box and the hitch is adjustable. Some of the part numbers are: KK4217-B this is a spacer between the blades, KK4930 this is the bushing mount, KK4233 this is the blade cleaner and another part number is KK4231-R. Thanks alot your help is much appreciated. I put this disc behind my 1939 "B" recently, it was the first time I have disced for about 35 years..it was great!!
Paul
06-30-2003 12:52:46
 Re: John Deere Disc Update in reply to Harry, 06-29-2003 18:15:42
I believe it is a model JB or JBA. The JBA would be slightly newer than the JB. These were made in the very late 30's into the middle 40's. My parts index only narrowed down the model to J, JB, JA, or JBA on those part numbers given. The J and JA would be single action where the JB and JBA had the back gangs for double action. Essentially the J was just a JB without the back gangs since the back gangs and frame attaches to the front in a ball socket. You can go back and forth between single and double action quickly.
Dan
06-29-2003 21:01:26
Is this a wheel type or drag type disc? If you have a JD dealer nearby you might hit them up with part numbers and they may be able to narrow it down for you.
