2020 JD WITH 48 LOADER WON'T GO UP OR TILT
B GUBRY
06-28-2003 12:23:22
LOADER SUDDENLY STOPPED WORKING, WILL BARELY GO UP OR TILT BUCKET, UNLESS I WORK THE CYLINER LEVER ON THE SIDE OF THE SEAT FOR THE REMOTE CYLINDER. I GET THAT IN JUST THE RIGHT POSITION TO WHERE YOU CAN HEAR OIL PASSING THROUGH IT WILL THEN WORK, GET IT I LITTLE TO FAR PAST AND IT QUITS, HAVE CHANGED FILTER AND CLEANED THE SCREEN AN DID'NT MAKE A DIFFERENCE. EVERYTHING ELSE SEEMS TO WORK GOOD.
Brokenwrench
06-28-2003 13:56:26
 Re: 2020 JD WITH 48 LOADER WON'T GO UP OR TILT in reply to B GUBRY, 06-28-2003 12:23:22
A little more info would help. Is the loader plumbed through the remote, or is it connected to the tractor directly with its own valve? Are there quick connects on the loader hoses? If so try disconnecting them and reconnecting them. Sometimes they get worn to the point where they will not let oil pass. Also check the hydraulic pump coupler to make sure it is not stripped.
