FH Rear Rims
J.P. Morgan
06-27-2003 09:32:07
I recently purchased a brass tag "B" for restoration & it came with two other "b's" for parts as well as two rear spoked F&H rims loose with out hubs . My question is will the John Deere hubs work with these rims or did F&H make hubs for their rims ?
Paul
06-28-2003 19:04:07
 Re: FH Rear Rims in reply to J.P. Morgan, 06-27-2003 09:32:07
Yes, the JD hubs will work. The F&H rims you got with the tractors must be of the later type which had the bolt in hubs. This simplified things for JD and F&H in that they could have less part numbers of rims that would still fit many different tractors by applying the proper hub. The original wheels for the B would have had the 10 spline hub cast in the wheel center. It may take some good searching to find a set of of 10 spline bolt in hubs as they seem to be a little scarce, around here at least. Good luck with the restoration.
