Ammeter wiring question.
T.J
06-27-2003 03:38:36
What is the correct way to wire in a ammeter for a 6v john deere. Where to you connect the leads.
John T
06-27-2003 05:06:51
 Re: ammeter wiring question. in reply to T.J, 06-27-2003 03:38:36
Good Morning TJ, The answer depends on if you're at positive or negative ground, cuz if wired backwards, the ammeter would read backwards i.e. show discharge when charging and charging when discharging. All 2 cylinder John Deeres were shipped from the factory as positive ground.
The conventional wiring on most tractors is for one of the ammeter leads, the "supply side" to be connected to the ungrounded battery post, either at the battery itself or more often to the starter terminal which has the big cable leading to that same post, and thats the only wire on that terminal. The other ammeter terminal, the "load side" is what feeds all loads (except usually NOT cigarette lighters) such as lights, switches, and igntion PLUS the BAT terminal on a Voltage Regulator (or BAT on 2 wire cut out relay systems) so the generator can get to and charge the battery.
On many ammeters, the terminals are labeled + and - , and on negative ground autos most were connected as, the + was the "supply side" and was wired to the + battery post whie the - "load side" was wired to lights and ignition and switches and voltage regulators etc. However, at positive grond that would be reversed, the + terminal would feed the loads, while the - terminal would be wired to the ungrounded negative battery post.
If you wire yours up and are unsure, wire one terminal (only wire there) to the ungrounded battery post or starter post with the big battery cable,,,,, ,,,, and wire the other side to all loads like lights or switches and ignition PLUS the BAT terminal on a Voltage Regulator or Cut Out relay. Then turn on the lights or ignition etc., (without starting the tractor) and the ammeter should swing to discharge, but then swing to charge if the tractor is startred and ran at fast RPM if your chargign system is working. If it does just the opposite of that, reverse all the leads.
DO NOT forget the generator has to be wired on the ammeters "load" side with the lights and switches and ignition etc., so it can get to and charge the battery. That way the ammeter will show whether or not net current is flowing out of the battery (discharging) or into it (charging).
Hope this helps and answers your question.
Good Luck n God Bless
John T Nordhoff in Indiana
Clooney
06-27-2003 03:55:11
T.J., it would help to know what tractor & engine you are working with. ~The common ammeter hook up would be the battery non grounded post [or starter battery cable stud] wired to one side of the ammeter [most aren�t marked so just pick a side] & ALL other loads & wires hooked to the other [non battery side]. That way all the current TO & FROM the battery goes through the ammeter & is measured. ~If, after you have it wired & running the ammeter reads backwards just reverse the wires from side to side [post to post] & it will then read correctly.
~The exception to the above would be the cigarette lighter [if you have one] it would hook to the battery side of the ammeter due to it's high current draw.....
John T (Yo Clooney)
06-27-2003 05:10:08
 Re: Re: ammeter wiring question. in reply to Clooney , 06-27-2003 03:55:11
Yo Clooney, Yesterday I received an e mail from you with attached pictures called new pics of shop or somethign like that. What is that attached file??? It acts wierd when I try to open it??? John T
Clooney
06-27-2003 06:26:49
 Re: Re: Re: ammeter wiring question. in reply to John T (Yo Clooney), 06-27-2003 05:10:08
John, it didn't come from me...If I send you anything with an attachment it will specify the attachment name & what is in the attachment plainly in the main text. ~DON'T open that attachment it is more than likely a virus or worm that came from somebody�s address book that had my address in it..
John T
06-27-2003 09:44:55
 Re: Re: Re: Re: ammeter wiring question. in reply to Clooney , 06-27-2003 06:26:49
Thanks clooney man, I thought maybe it was safe since from you and mentioned a shop etc., but I think its a virus and my anti virus is working on it now. Take care John T
