Hand Start D
Dave Brown
01-13-2004 17:51:51
Ok, this tractor was timed wrond with the # 2 cylinder firing first. I took the mag off, turned the flywheel to the L.H. Impluse mark, put a new Magneto on did what the book said to do, except I did not put that little ground wire in, since it was a new mag, hand tightened the bolts, turned the fly wheel one complete revolution, tapped the top of the mag back until it popped, then tightened the bolts and hooked up the spark plugs. Then I tried to start? Well the right cyl is firing first so that is good, but she is stil a bear to get started. maybe it is the spark plug wires and spark plugs. Any ideas????
She poes sound like she wants to go, but never catches???
Clooney
01-14-2004 03:52:41
 Re: Hand Start D in reply to Dave Brown, 01-13-2004 17:51:51
Dave, I'm still not convinced your timing is correct.. Your statement "Well the right cyl is firing first" kind of bothers me. The L/H [flywheel] side actually sparks first as the flywheel is turned but that is relative to where you are in the firing rotation..
~There is an easy solution.. First pull both spark plugs out,, then put the plugs back in the plug wires & lay them on the engine block where you can see them both.. Now turn the flywheel in the starting direction & watch both the plugs & the flywheel.. You need to see the L/H [flywheel side] plug spark as the �L/H impulse� writing on the flywheel is directly to the rear & the flywheel slot is running straight for/aft,, Then you need to see the R/H [clutch pulley] side plug spark as the �L/H impulse writing on the flywheel is straight forward & flywheel slot is again running fore/aft.. If that is happening you are timed correctly [or at least close enough to start it]�
The above assumes a Wico C or X mag.. If you are running an Edison-Splitdorf or AP mag your spark MUST also happen when the side that sparks has compression, so if you are using a gear reduction type mag hold your finger over the plug hole & make sure you also have compression as the spark occurs..
~For your starting timing to be totally correct your L/H spark plug should spark as the �L/H impulse� writing on the flywheel lines up with the case mark on the trans case [at 3 o�clock directly behind the flywheel & at the same height as the center of the crankshaft]. But if it is within 1� inch above the mark & within �� bellow the case mark it should start ok..
~Once you get it to spark at the correct time per above see if it then starts,, if not try NEW spark plugs,, if it still won�t start post back for other options & starting trouble shooting.. That spark MUST happen at the correct time or it will never start..
[email protected]
George
01-14-2004 01:48:05
Hook up a timing light to the LH plug (with either a battery or battery charger to power it). Note where the Impulse mark is when it flashes in relation to the casting mark. Found this to be more accurate than listening for the impulse. If you also put a piece of tape where the advance should be, you can see what the timing looks like when running. (Had a starting problem similar to what you discribe on a newly purchased B -- the Impulse was right on but the advance was almost twice what it should be, 65 degrees versus 35 degrees. It would fire but not run.)
Also, on my D, it is very sensitive to flooding -- I roll it through two compression strokes on full choke, then go to half choke. I am sure every one of these old tractors have their unique starting tricks.
