Broken Slider Tab inside transmission on JD A
06-26-2003 09:26:51
Help, Broke the slider fork tab on inside of transmission on JD A. Should I try to weld it back on or take apart. If it has to be removed, how do you disassemble and reassemble ?. (It is a customer tractor) Thanks in Advance as always.
Dave K
06-27-2003 18:13:53
 Re: Broken Slider Tab inside transmission on JD A in reply to [email protected], 06-26-2003 09:26:51
A couple of the slider forks on mine have been brazed and work fine.
Diesel Don
06-26-2003 16:28:16
I just disassembled a JD A tranny. I can't tell exactly what you need to know from your post. Can you be a little more specific? What gear is involved? Is it a 6 spd or 3spd with hi/lo range? Where is the part located? References to a JD parts manual would help if you can get them. My tractor is a 6 spd but I think they are similar enough that I may be able to help you out anyway.
