HELP- How do you line your magneto gear back up?
JD Mike
06-26-2003 06:31:55
My dad just bought a home made drilling rig with a 2 cyl gas powered John Deere eng..it has a bubble screen over the rad so i assume its out of a combine....I'm not too familiar with this older beast. On the block is stamped 4.13.D. It has a mag ignition (on left of eng) and a little slide flapper on the bell housing.....When i turn the engine over there is a line with spark written over it which I assume lines up with the mark on the block for timing. The mag gear does have a dot on a tooth but its on the front face towards the rad which I assume is the same on the eng gear....maybe use a dental mirror to see the dot on the eng gear without pulling the front cover?....can I use that spark line on the flywheel?....I told my dad not to pull it to clean the points but....thats my dad!
