630 Steering shaft
Greg
06-26-2003 05:48:13
My 630 is leaking power steering oil from the steering shaft oil seal housing, I have been told there is a O-ring in the housing that needs to be replaced. In order to remove the housing you must remove the steering shaft from the housing. How much disasembly of the steering shaft is required to slide it back far enough to clear the housing and how is it done.
Gordon
06-27-2003 04:58:46
 Re: 630 Steering shaft in reply to Greg, 06-26-2003 05:48:13
You have to start at the top,and work down. You need a book there are shims and torque settings The shaft will not come out the bottom.
Paul
06-26-2003 19:41:39
Once you get your steering shaft pulled out of the support its really easy. This is a bit more work on the 30s to get the steering shaft out since its got a couple of u-joints you have to take your rear cowl loose to pull the shaft out of the long support memeber. This support member is where you will find your o-ring that is leaking. With the shaft out its just (2) 3/8 bolts and its off. A new o-ring and gasket and you're ready to go back together.
