Jd fuel pump interchanges?
Bill
06-25-2003 19:36:56
Can you replace a forward mounted rotary pump with a inline pump on a 4230?
davidval
06-26-2003 01:50:32
 Re: jd fuel pump interchanges? in reply to Bill, 06-25-2003 19:36:56
basically, it is possible, you must look at the pump mount on the engine block for plugged holes for the 4 studs used with inline pump. you must have the bosch type injectors for the inj. pipes to fit. you will need all the fuel lines on the engine, the fuel filters with base, the speed control rod, the lift pump opening cover and the pump gear. you will also have to set the pump to 4230 delivery specs. david
