John Deere F725 Problem? Major help needed please!
Soccer Kid
06-24-2003 19:45:25
Hi, I know the F725 isn't exactly a "tractor" but this is the best forum I could find and someone might be able to help. I work for the city and we use a F725 to mow the cemetery areas.
The mower deck is having a problem though, the belt keeps coming off and at the same time it loosens all of the nuts on the pulleys and in 2 cases the blades fell off. I'm the only one that uses this mower most of the time and my boss said in the last 5 years he has never seen a mower do that. But it has done it 3 times and every time it does it it breaks the belt. I think my boss is getting pretty pissed and I don't want to lose my job, what might be causing this to happen does anyone know?
Jack
06-26-2003 09:01:07
 Re: John Deere F725 Problem? Major help needed ple in reply to Soccer Kid, 06-24-2003 19:45:25
You probably have spindle bearings that are shot, allowing the sieves to wobble & chew up belts. If the bolts on the sieves are coming loose, there may be a blade balance problem as well. With the machine seeing use in a cemetary, it's surely hit an occasional gravemarker or tree root, both of which can cause this condition. I'd start there...
Soccer Kid
06-26-2003 11:11:32
 Re: Re: John Deere F725 Problem? Major help needed in reply to Jack, 06-26-2003 09:01:07
Yes, the bearings in 2 of the pulleys were no good...what's strange though is that they were fine when he fixed the problem the first time, then the second time the bearings locked up, and then it happened a third time with a new pulley.
I'll talk to him about it tomorrow and tell him what you said.
WjW
06-24-2003 21:26:43
Sir, I don't know anything about you model of machine But here's a thought.
Did you just replace the belts?
Is it possible to route the belt on such a manor as to run the blades backwords and therfore loosen all the nuts? seems like most things that rotate like that rotate in the direction such that it is constantly trying to tighten the nuts.
Does any of this make sence? Maybe none of these thoughts can apply
Post back I'm curious as to you out come.
Soccer Kid
06-24-2003 21:33:20
 Re: Re: John Deere F725 Problem? Major help needed in reply to WjW, 06-24-2003 21:26:43
Thank you for your reply!
The first time it happened the belt wasn't BRAND new, but it was in good shape (I inspect the belt before starting up in the morning) but it broke, the other 2 times the belt was brand new.
I don't repair the machines, my boss does, I'll take a look and see how the belts are fashioned to the machine and ask him.
My thing is tho, that he has been manager for 5 years and probably have run the belts in the same fashion as he is now. We have another mower, same model same brand everything just more hours and it doesn't do this and the belt is routed the same way! Strange isn't it? I'll check into that tomorrow morning though and let you know tomorrow after I get off work (or after I'm fired, whichever comes first I suppose).
I really appreciate your help! Thanks a bunch!
