Carb float for D model
John
06-23-2003 21:11:53
I hope you folks might help me. I am told that a float from a JD Model D tractor carb can be adapted to my very early Model T carburetor (1912). What I need to know is the O.D, I.D. and height of just the brass float. Ideally the float I need would be 2-5/8" O.D. and 1/2" to 5/8" tall with at least a 1-1/4" I.D. I am not a tractor guy but do make some parts for the 2N/9N folks. Sure would appreciate some input on this item and where I might get one if indeed it could be adapted. I think I can adapt most any round donut shaped float so long as it is not too big O.D. or too small I.D.
Thanks.
Mark
06-24-2003 15:07:17
 Re: carb float for D model in reply to John, 06-23-2003 21:11:53
If you get one for an H, it is not as thick as the ones used on the A's etc. it also doesn't have the arm to remove.
John
06-25-2003 06:58:22
 Re: Re: carb float for D model in reply to Mark, 06-24-2003 15:07:17
Mark:
Thanks for the input. Do you know the O.D. and I.D. of the "H" float and perhaps a JD part number? A thinner float would definitely be better because the .910 of the D float is going to be a squeeze and I am somewhat concerned that I may not have enough float level adjustment.
Thanks.
Earl S.
06-24-2003 14:35:23
Deere Part # AR 10066 Float for DLTX seies carb is .910 thick or deep 1.765 ID 2.685 OD. fits A,B,D,G, Earl In Illinois
John Regan
06-24-2003 14:50:08
 Re: Re: carb float for D model in reply to Earl S., 06-24-2003 14:35:23
Earl:
Prexactly what I was looking for!! And a fellow Illinois guy too. Thanks a bunch. I owe you guys.
