JD 40 CARB CLOONEY
DOUG
01-13-2004 16:06:12
Still a no go. Put new nozzle in lowered the float some still can't set idle. Run card cleaner through all the holes even used a pin light. Wondering what the float level should be. I have a M JD all restored, hate to break paint but if float level doesn't do it I will try it. Hate to send to Roberts with all neww stuff in it. THANKS DOUG
Clooney
01-13-2004 17:21:57
 Re: JD 40 CARB CLOONEY in reply to DOUG, 01-13-2004 16:06:12
Doug, I don't remember what your original complaint was [seems like maybe a rich idle],, might need a refresher on your original problem.
~The float level should be 1/4"-9/32" measured from the top end of the float opposite the needle to the casting gasket surface.
~Did you clean the idle channel & restriction in the bottom casting that leads into the main well?
~Did you get the throttle plate back facing correctly? [ID number facing up]
~Did you center the throttle plate in the bore & get it to fit correctly all the way around?
~Is the throttle shaft worn & sloppy? [if so replace it].
~How about cleaning the economizer passage & restriction? [that is more of a mid range thing though]
~Remember that idle screw is an air needle & not fuel so backing it out leans the mixture [opposite of most carbs].
~Did I already send you a carb cut-a-way showing a cut view of the carb passages? If not let me know [you will need good eyes to read it].
[email protected]
DOUG
01-14-2004 03:01:18
 Re: Re: JD 40 CARB CLOONEY in reply to Clooney , 01-13-2004 17:21:57
I have had this thing apart boilled out all the little jets out wire run through all passages 5 times now still can take idle screww out and doesn't make any diff. Surges anything below 1/4 throttle. Has to be in Idle system. THANKS DOUG
Clooney
01-14-2004 03:59:40
 Re: Re: Re: JD 40 CARB CLOONEY in reply to DOUG, 01-14-2004 03:01:18
Doug, how about when you screw the idle screw all the way in.. Some of those 40's like the idle air screw all the way in.
~Another thing to try is removing the carb throttle rod & operating the carb throttle lever by hand.. If the surging quits & the idle settles down your problem isn't in the carb..
~If either of the above doesn�t help then you probably should try that other carb..
[email protected]
tom [wayne - your 40 carb
01-14-2004 06:25:44
 Re: Re: Re: Re: JD 40 CARB CLOONEY in reply to Clooney , 01-14-2004 03:59:40
Wayne,
As i recall it, you have almost all your carb's idle screws all the way in - do you have the same issues as doug? read the entire post - what do you think?
tom
Wayne in Tn.
01-14-2004 07:11:57
 Re: Re: Re: Re: Re: JD 40 CARB CLOONEY in reply to tom [wayne - your 40 carb, 01-14-2004 06:25:44
I am not sure what Doug is saying the problem is, if it is surging or (hunting) the governor may need some attention, you really need the service manual to attempt setting the linkages on the gov. As to the carb. seems he has done everything to it. First I would have the engine running at wide open throttle, then turn the power screw (on bottom of carb) IN until the engine sputters, then back it OUT one turn. Then turn the air screw (on top of carb) for best idle, a lot of mine seem to idle best with this screw all the way IN. Maybe because I am getting enough air around the throttle shafts, ect.
tom
01-13-2004 16:25:44
Doug,
Carb float should be set @ 1/4"...i know those carb issue's can drive you crazy, but if you are sure you have all the passageways clean/cleared, then it has to be something mechanical:
* have you check the choke/butterflies to see that they are fitting tightly?
* is the felt seal and retainer properly set in where the throttle shaft resides?
* did you not only clean the passagesways, but remove all the brass orifices, clean them and their holes?
* is your air-breather operating properly?
* have you adjusted your load needle and idle screw to the proper factory settings, then try the fine-tuning process?
* are you using a quality gasket and you did not use sealant, and all the screws are set at the proper torque?
let us know,
tom
