Help! 4010 propane
Slim
06-23-2003 18:16:43
I have a 4010 propane that has recently developed a problem that has me stumped. The tractor will fire right up, but once it gets warm it begins to back fire and spit and sputter and then dies. It will not crank again until it has cooled off. Does anybody have any ideas what could be causing this? Any help would sure be aprreciated. Thanks,
Gary in TX
06-24-2003 10:03:15
 Re: Help! 4010 propane in reply to Slim, 06-23-2003 18:16:43
Yall don't forget the condenser as well. Heck sounds like the ole girl might be ready for a full ignition tune up anyhow. I know I was having problems last year with my 135 Massey like that. Points and cond. fixed her right up
Dick Kline
06-24-2003 09:05:59
I vote for the coil.
fox
06-24-2003 05:45:39
It sounds like it is freezing up.
Are you running anti-freeze or straight water?
Make sure coolant is going to the converter and check the converter for iceing.
C
06-23-2003 21:20:44
Igniton coil break down after it gets hot.
Bill
06-23-2003 19:49:59
Im going to guess , you may not believe me but Im saying weak batteries ,I may be way off but we had a similar problem, did everything, then replaced batteries , and zooooo m, away she went, My humble advice,,,,Bill
slim
06-24-2003 12:12:20
 Re: Re: Help! 4010 propane in reply to Bill, 06-23-2003 19:49:59
Do you mean the thermostat in the motor for the cooling, I have been thinking this tractor is getting warm too fast, is that the thermostat you are talking about. Thanks
jerry
06-24-2003 06:25:27
I would check to make sure you are running a thermostat and that it is a good one. A propane engine will not run without a thermostat as the regulator has to convert the liquid to vapor.
