430 W hydroulics
Dale Kite
06-23-2003 17:17:09
Was raking hay today with a 3 point wheel rake and the lift would not stay down it kept easing up and i had to hold it down by hand whitch gets tireing. Iv'e heard of the lift leaking down but never heard of one leaking up. Any help would be great.
JB
06-23-2003 20:19:43
 Re: 430 W hydroulics in reply to Dale Kite, 06-23-2003 17:17:09
Hi, was the top link adjusted too long?
JD had a draft control sensing on the top link mechanism. Just behind the seat and below the top link pin was a big spring inside a metal casting.
Depending on the pressure or load on the top link the spring would compress or stretch. The movement allowed by the spring was translated by a control arm to the 3 piont hitch lift lever to raise or lower the implement. This was supposed to be feed back loop to keep the plow at a constant depth in the ground.
Never worked very well on JD 420 that we had.
The other thing was a jam nut on the 3 piont hitch lift control lever that tightened against a friction washer to hold the lever in one place. After a lot of use the nut required tightening to
keep the lever from creeping up or down.
Good Luck
JB
