730 gas fuel gauge question
Larry G
01-13-2004 15:17:54
I got home my dads old 730 Gas today and most things seem to work. It has been converted to an alternator and neg. ground of course. All gauges seem to work except the fuel gauge just stays on empty. I have not had time to look at book or under the hood yet. Any ideas?? Will the original gauge work on a neg. ground system?
Bo in Maryland
01-14-2004 12:02:34
 Re: 730 gas fuel gauge question in reply to Larry G, 01-13-2004 15:17:54
"All gauges seem to work except the fuel gauge just stays on empty."
..... the fuel gauge on my 730D stays on empty all the time too.....but there's a shiny button on the dash [looks like a starter button next to the fuel gauge] that you push and the needle jumps and registers the correct fuel level in the tank..... .at any rate, that's the way mine works.
Good luck to all!
Bo
MIKE HANLEY
01-13-2004 22:24:45
I thought you would have an answer by now and I don't know. It's been so long now I can't remember if the fuel gage was working on the 630 at the time we converted it to NEV ground with an ALT or not. I do remember that when we converted the main 730D from 24 VOLT to 12 VOLT NEV ground that gage no longer worked and the other 730D's gage never did work. All three tractors now have a complete gage set from J.C. WHITNEY 1-800-529-4486 ordered out of catalog # 681C-12 (NEED NUMBER TO ORDER). The part # is 12UL4229X. It is a ajustable float with a gage for all 12VOLT NEV GROUND SYSTEMS. Cost; $22.95. With the ajustable float you can set it so it reads right on the money right down to the last drop. I can read the gages and tell you within a quarter of a gal how much it will take no mater where the gage reads (1/4 1/3 1/2 3/4 etc.)
