Impulse on a Wico X
Jamie
06-22-2003 18:30:39
I have a Wico XH 1042 mag that was rebuilt but I ran into some problems putting it on my B. I did not think the impulse was working so i took off the drive coupler to inspect it. Nothing is broke, but my question is how do I put the drive coupler with the impulse spring back onto the shaft? Does the spring have to be wound a few turns before placing it on the shaft or does it just go straight on? Ahy help would be appreciated.
Thanks,
Jamie
Clooney
06-22-2003 18:52:23
 Re: Impulse on a Wico X in reply to Jamie, 06-22-2003 18:30:39
Jamie, yes the spring has to be wound up when installed. The amount of wind up depends on the cup number but most are 1 turn.
~If you post or send me your E-Mail I will send you a rather long setup procedure on installing that spring & setting the impulse cup up.
[email protected]
