Gas in Crankcase Model 60
RJR
06-22-2003 16:33:43
Changed oil and had 5 gals of gas in crankcase,
replaced the needle/seat, checked it again and still getting gas in crank case...any suggestions
what to check next? Thanks.
Bill R
06-22-2003 16:39:38
 Re: Gas in Crankcase Model 60 in reply to RJR, 06-22-2003 16:33:43
check the diaphrams in the oil pressure unit that operates the gas shutoff--located on top the sediment bowl--these are still availible from your John Deere dealer. Its the first thing i would check, have fun
RJR
07-03-2003 16:28:55
 Re: Re: Gas in Crankcase Model 60 in reply to Bill R, 06-22-2003 16:39:38
The diaphrams did the trick...thanks much!
weedbender 60
06-28-2003 10:54:54
I agree!! The gas shutoff valve is probrally the problem, what worked good for me to fix this problem was to put a manual shut-off valve down stream from the oil pressure valve. Bought the parts from an automotive store, cut the gas line and installed manual shut-off with compression fittings. Not stock but saves the main and rod bearings from seizing and scoring from having gas in the oil. A $20 dollar investment can save life of the engine and a expensive rebuild
