Hi again 60 guy, Yep your post is back a page and there were plenty good and interesting comments last time which hopefully helped you out. Now to your new questions. If it were previously ran without a ballast resistor but one was required, that caused excess current draw which can drastically reduce the life of the contact points. Such usually renders them black and over carboned. HOWEVER, I doubt that alone or even if they are worn down now can cause her to over heat all that much. Being off time is only one of many possible factors contributing to over heating such as a clogged radiator, faulty thermostat or water pump as all reported in response to your earlier post. (See page 2) To answer your specific question, if the points are worn excessive like if the cam follower is worn etc., it changes the gap and dwell angle which affects the timimg and indeed, off timing gan contribute to over heating. HOWEVER AGAIN, slight point wear or slight off time caused as a result of that may be a minor but not a major factor in over heating assuming the timing isnt drastically off. By the way, whats she timed at now??? Unless way off 20 to 30 BTDC running, I doubt that is any problem causign over heating. As we posted below, you can check the thermostat and guage by immersion in boiling water and observe the gauges readign and whether or not the t stat opens and use an air gun to blow and clean out the radiator fins and see what happens. Thanks for re postign and keeping this a "hot" topice lol, overheatign (if yours actually is) is a common problem. God Bless John T Nordhoff in Indiana
