3010 hydraulic fluid leaking
Eddie
06-21-2003 20:41:07
Hydraulic fluid leaking in the front. It seem to be coming from under the fluid cooler...I guess it is what you call it. not sure what it call. But it leaking fluid down on the front wheel. Any suggestion or ideas? Thank Eddie
Matt
06-22-2003 18:13:16
 Re: 3010 hydraulic fluid leaking in reply to Eddie, 06-21-2003 20:41:07
My 3010 is in the shop right now getting an overhaul. I told them to fix the hyd leak up front when they had it apart. I went up yesterday to look at it and he said it was leaking at a fitting on top of the cooler. Looks like you would have to take the hood off to get too it easly.
Bill
06-22-2003 09:00:57
Could be a lot of things, but I would look for a metal line that wore thru somewhere, or line that cracked at end do to fatigue, Your cooler could have wore thru on bottom or popped a weak seam, if you could clean area then run tractor to see exactly where it leaks, good luck Bill
