JD 567 Wheel Rakes
MIKE HANLEY
06-21-2003 07:20:17
Finished haying yesterday. Thought I would put in my two cents worth on 567 Wheel rakes. I think they are the best rakes ever built. I have seen alot of used ones lately showing up at auctions and just by looking at them, I can tell privious owners did not have an operators manual or read it. If the tires have 8 to 12# of air in them and the lift at of the springs are set at 5# you can't beat this rake. When set rigth the wheels go over rocks and dead farrows like they wern't even there. We have two of them and about 5 years ago JD teeth were getting pricy. Bougtht the rubber mounted teeth from a farm supply store for $1.39 each and cut off about 6" on the end of the teeth and we haven't had to replace a tooth since. We rake with the 730Diesels in 5th gear
