Roll O Matic on JD A
Keith
06-20-2003 18:50:26
When did they (year) start putting Roll O Matics, and Powr Trol on JD A's. Serial number is not readable. Thanks
Richard
06-20-2003 20:22:22
 Re: Roll O Matic on JD A in reply to Keith, 06-20-2003 18:50:26
1947 on the roll o matic fronts. Hydraulics have been available on Deere's since the 30's, don't know when Deere coined the term Power troll.
F-I-T
06-20-2003 20:32:26
 Re: Re: Roll O Matic on JD A in reply to Richard, 06-20-2003 20:22:22
I believe that the Por-Trol system came available the same time as the Roll-A-Matic. The earlier hydraulic system was called "Powr-Lift" and was an all the way up or all the way down hydraulically operated rockshaft only. Powr-Trol added the feature of variable position of up and down, as well as the capability of powering a remote cylinder.
I could be wrong, but the S/N 477,000 sticks in my mind as the point of availability.
Frank-in-Tallahassee
70D // 855
Stan - Florida
06-21-2003 04:48:08
 Re: Re: Re: Roll O Matic on JD A in reply to F-I-T, 06-20-2003 20:32:26
Frank,
I believe 477000 was the start of the styled models, in the 1939 model year. 584000 was the start of the "late styled" models, with the pressed steel frame, square seat, Powr-Trol, Roll-o-Matic, etc.
Best regards,
Stan
F-I-T
06-21-2003 07:23:47
 Re: Re: Re: Re: Roll O Matic on JD A in reply to Stan - Florida, 06-21-2003 04:48:08
Yes, Stan, I'm sure you're right. I just could not remember. 477,000 was stuck in my head.
Thanks !
Frank
