JD 425 (new) fuel pump fuse location mystery
Brit
06-20-2003 17:57:47
anyone know where JD hides the fuel pump fuse on a 2000 model 425? Book says its "on the wiring harnes but not with the other two fuses".
Steve - IN
06-21-2003 21:26:14
 Re: JD 425 (new) fuel pump fuse location mystery in reply to Brit, 06-20-2003 17:57:47
Brit,
I have the Kawasaki service manual for the engine on my 425. Looking at the schematic, it's a straight run from pin E on the key switch to the pump ---
except,
There's a connector which has an X in a box (not the normal fuse symbol on a schematic) that's labelled as a Yazaki 7114-2026-02. The connector has it's own ground, which is also something to check if the pump is not pumping. The manual says the pump should make 2.76psi or pump 180mL (~1/5 of a quart?) in 30 seconds. The manual says if it doesn't, toss it and install a new one, no servicable parts in the pump.
good luck....
