1020johndeere
rich adams
06-19-2003 17:28:49
i am having problems with my 1020 john deere gas.when engine is running it misses out and then engine dies. it has been in the past the points.I recently changed the points and now it will not run properly. also it seems to act up when the engine is hot. any suggestions.
buickanddeere
06-20-2003 06:35:56
 Re: 1020johndeere in reply to rich adams, 06-19-2003 17:28:49
Even if the problems are ignition, it can't hurt to locate and clean that gas filter. Dad's gas 2020 had mystery stalling for months until he found the filter hidden in the carb inlet fitting. It wa sfull of loose flaky stuff that would on occassion pack tight and block fuel flow.
Steve - IN
06-19-2003 23:01:43
Rich,
Just 'cause I'm a natural cheapskate -- before you buy a solid state ignition, did you change the condensor when you changed the points? A bad one can cause the kind of problem you're having.
Also, second thought is check for fuel starvation. Crud in the gas tank is a gift that keeps on giving, it seems. Usually a good test is when it starts missing, if you pull out the choke and it clears up -- it's just not getting enough fuel.
Good luck with the 1020 --
Steve
('66 1020 with original distributor)
WjW
06-19-2003 17:39:28
Rich,
If you are guessing ignition trouble, coils can act up when warm, do you get a good blue spark when it's hot? or is it kind of yellow. I've also had my fair share of poor condensors file up a good tractor. Recently I went to a electronic ignition from Genesee Products, on a gasser here at home after all the great reviews here on th forum. You won't regret it. The old points ignition is fine too. as many here will attest but the electronic is more burden free. This is all assuming an ignition problem
richadams
06-19-2003 17:52:00
 Re: Re: 1020johndeere in reply to WjW, 06-19-2003 17:39:28
have you got any more specific information on the genessee products electronic ignition. address,email address sounds interesting if it would be trouble free.
WjW
06-19-2003 18:25:38
 Re: Re: Re: 1020johndeere in reply to richadams, 06-19-2003 17:52:00
If you get the Green Mag. it's in there otherwise
www.geneseeproducts.com 918-274-8000
TThey should be able to ask the rigt questioins to you to get the right product to you took 5 bus. days for mine good luck
