Hey Mr Clooney
Larry806
06-19-2003 14:32:51
I got a 70 in yesterday that leaks power steering oil. It comes out & runs down the frount post between the wheels any ideas off the top of your head ( I hope it is a easy fix) I don't think I'll get time to do much of a tare down till after wheat harvest now Thank you for your time Larry
Clooney (slow loading pi
06-19-2003 14:58:50
 Re: Hey Mr Clooney in reply to Larry806, 06-19-2003 14:32:51
third party image
Larry806,unfortunately that probably isn't an easy repair...The usual cause is the lower seals ["O" rings] on the Power steering spindle leaking, [see red arrows]..That basically means the whole pedestal has to come apart.
~It isn't to awfully expensive & isn't even a very extensive repair but does involve a fair amount of disassembly & time consuming work.
~If you want to tackle it we can easily talk you through it..
Larry806
06-20-2003 09:15:41
 Re: Re: Hey Mr Clooney in reply to Clooney (slow loading pi, 06-19-2003 14:58:50
Thank you for your time. I have a couple days planting to finish & get combines ready to cut wheat I'll get in to it after wheat I'm sure I'll have more questions Larry
G.V.J.
06-20-2003 04:44:50
Hi. Clooney I just did a 70 and your right a lot of time. I own Rural Restorations a full service restoration shop in south East Ariz.. Working on a corn bore D do You know of any 6.500 Pistons available? You can E-Mail Shop at Rural Restorations@ Yahoo.com
Clooney
06-20-2003 15:28:44
 Re: Re: Re: Hey Mr Clooney in reply to G.V.J., 06-20-2003 04:44:50
G.V.J., Kevin Stober [610-845-3668] has [had] 6.5" pistons for the U/S "D". If he has them in stock he usually has about 3 oversizes available. ~Problem is if he doesn't have them in stock he waits for a few orders before he has new ones made.....
