Ray: So, it sounds like the pony starts, runs, but slowly heads to a stop without maintaining the idle. How does it work if you shift it to high speed ("Run")? Probably does the same. I have a few places for you to start, but it sounds like it could be fuel related. Check and clean the air cleaner. It serves as a source of vent air for the diesel crankcase, so it could be crudded up. If you hold the governor rod open by hand does the pony high-speed stay where it should be? If so, you might just need to adjust the high-speed spring bracket. If not, check the fuel line from the tank for flow, and the tank for dirt/debris/crud. Old fuel lines can crack inside and a splinter can block the fuel flow. Also, the ponies like a more towards full than towards empty fuel tank. Check the fuel flow from tank through the line through the shut-off valve to ensure full fuel flow to the carburetor. Next, those ponies really like nice clean spark plugs. If they are beginning to foul a bit, put in a new set of Champion J-8C's. They are used in a bunch of small engines, so they are pretty cheap. You might want to check the points and freshen them up, and check the voltage you are getting at the pony distributor while it is running. They will misfire and slow to a stop if the voltage is low from a poor/dirty connection. You might have to add a bit of load screw to get it to carry itself. Adjust that warm while motoring the diesel over on full compression. To adjust full speed, you move the angle iron bracket with the spring attached away from the carburetor to increase, toward the carburetor to decrease. If you have a hand tachometer it makes setting the speeds easier. Now if none this helps, you could have trash in the carburetor bowl that is occluding the main jet. When I dropped the bowl on my 70D carburetor, there was all manner of trash in it, and after a quick clean up and new gaskets, it worked like new. Frank-in-LA
