What to use to clean surfaces before JB Weld
Scruffy
06-19-2003 07:58:27
After roughing up two metal surfaces to be JB Welded what should I use to clean the surfaces of any oil, residue, etc?
thanks,
scruffy
Gomer
06-19-2003 23:22:22
 Re: What to use to clean surfaces before JB Weld in reply to Scruffy, 06-19-2003 07:58:27
Today---I've been cleaning some parts with Brake Parts Cleaner. (Spray Can) Seemed to work well.
The surface was clean and dry and evaporates quickly.
JD60
06-21-2003 21:13:35
 Re: Re: What to use to clean surfaces before JB We in reply to Gomer, 06-19-2003 23:22:22
I wire brushed the surfaces, then used acetone. Done right that stuff really really works. I filled in worn crank splines and pushed my flywheel on and its holding now for 2 yrs. $4.00 JB Weld or $600 welding job??? hmmm
Jack
06-19-2003 21:48:13
All of the below methods of cleaning will work except STEEL WOOL!! Steel wool is very oily and you will be defeating your purpose. If you don't believe this just hold a match to steel wool and watch it burn. In fact SW is better off used for polishing than for roughing up.
F-I-T
06-20-2003 05:41:28
 Re: Re: What to use to clean surfaces before JB We in reply to Jack, 06-19-2003 21:48:13
Jack:
Steel wool doesn't burn because of oil...it burns because the iron is so fine that it allows rapid oxidation. Degrease some, let it dry, and light a match to it. It's a seventh grade science experiment.
Tim Reynolds
06-19-2003 12:43:27
I use a little murattic acid, then flush with water and blow dry with air!!!!! !!
F-I-T
06-19-2003 08:11:51
Scruffy:
You can use some MEK if you have it. Lacquer thinner as a second choice. If you can warm it with out damaging any adjoining paint, a propane flame will cook any residue to carbon. Then you just scuff it with steel wool and anything left will meld with the epoxy. The main contanimant to avoid is oil.
Frank
Scruffy
06-19-2003 08:16:37
 Re: Re: What to use to clean surfaces before JB We in reply to F-I-T, 06-19-2003 08:11:51
Please forgive my ignorance, but what is MEK. Is that the brand name and/or product name?
Thanks,
scruf
HAL
06-19-2003 08:30:17
 Re: Re: Re: What to use to clean surfaces before J in reply to Scruffy, 06-19-2003 08:16:37
methyl ethyl ketone i think you can get it at sherwin williams
F-I-T
06-19-2003 08:59:41
 Re: Re: Re: Re: What to use to clean surfaces befo in reply to HAL, 06-19-2003 08:30:17
Yep, Methyl Ethyl Ketone. A highly volatile aromatic hydrocarbon solvent. I bought my last quart at Home Depot in the paint thinner section.
Frank
steveormary
06-19-2003 12:15:24
 Re: Re: Re: Re: Re: What to use to clean surfaces in reply to F-I-T, 06-19-2003 08:59:41
I have used de-natured alchohol.
