Engine swap-466 to a 404
Wade Burt
06-19-2003 06:59:16
Can a 404 engine out of a 6600 combine be installed into a 4240 tractor? I know that the waterpump and oilpan must be changed . Will the bolts on the clutch housing line up? Any other problems that I might run into? The combine engine only had about 1700 hours on when stored and still runs as good as ever. Any advice or help will be welcomed.
chris
06-19-2003 19:39:30
 Re: Engine swap-466 to a 404 in reply to Wade Burt, 06-19-2003 06:59:16
Yah, the clutch housing will bolt right up, also the oil pump pickup tube and screen, throttle linkage(unless you're using the 4240 inj. pump), injectors?, exhaust manifold, front pulley/dampener, dipstick, fuel return line from the injectors, and possibly the thermostat housing will have to be exchanged. And replace the rear crankshaft seal while you're there. good luck chris
Bob
06-19-2003 07:05:34
Make sure you engine is drilled in the front for the 4 hydraulic pump adapter bolts. Some combine engines aren't.
