730 VOLTAGE
John
06-19-2003 06:52:47
Clooney & F-I-T: Thanks again for your help!!! I put the new switch and resister in yesterday and everything works. Eng. seems a little short on power, but I can start the tractor which is more than I could do for many years.
JOHN
F-I-T
06-19-2003 07:56:22
 Re: 730 VOLTAGE in reply to John, 06-19-2003 06:52:47
John:
Good Deal !
You might want to try adjusting the load screw after a good warm up. If you adjust it when it's too cold, it might load up on you and foul plugs when warm. Also, I have found that the high speed spring may need to be bumped a tad tighter and give it just a bit more of top end. That can someintes make a big difference. I don't feel it's the the high speed that kills ponies, it's the cold starts and lack of warm up.
Frank-in-Tallahassee
70D // 855
