JD2020
RG Soldier
06-19-2003 04:56:40
What type of oil do I put into the gear case that is located in front of the seat? The round plug has a dip stick attached and shows no oil in the case. My tractor is not moving at times . Hydraulics are ok. I have a cluch but you dont need to use it to shift. The shifter is located on the steering colum . Forward, forward at a higher speed and reverse. help!
Wade Burt
06-19-2003 06:45:16
 Re: JD2020 in reply to RG Soldier, 06-19-2003 04:56:40
I need some advice from someone that has done this. Can a 404 engine out of a 66600 combine be modified to fit a 4240 tractor. I know the oilpan and waterpump must be changed, but will the bolt pattern around the clutch housing be the same? Any help or advice will be welcomed.
John
06-19-2003 06:08:01
Are you sure you have a 2020? It should have a twin stick top shaft synchronized tranny, and as possible option, a forward/reverse shuttle on the dash. To add hydraulic oil the filler should be behind the seat not in front of it. Dipstick should be at the rear of the footrest against the rear end. Just above it is your tractor serial number. Post it in its entirety and maybe it will help in answering your question.
RG Soldier
06-19-2003 07:26:13
 Re: Re: JD2020 in reply to John, 06-19-2003 06:08:01
I stand corrected. There is a forward reverse on the dash. I have put hydraulic fluid in and the place where it goes sits right by the left rear fender. It has a sight glass. But down between my feet on the deck is the dip stick that Iam talking about. I was told it is a 2020 however maybe that is not correct. Iam deployed with the military so I cant check serial numbers at this time. RG Soldier
John
06-19-2003 08:29:30
 Re: Re: Re: JD2020 in reply to RG Soldier, 06-19-2003 07:26:13
My bet is thats not a 2020. The serial number will tell the story if you can supply it without violating national security. Its possible that its an industrial version of an agricultural 2020. maybe others will reply and can help.
