Oil filter on JD B
Joe M
06-18-2003 20:24:34
Have studied this problem for several days & am still not exactly sure where the problem is. Am fairly sure it is where the filter stud connects to the oil filter head. I only have one rubber gasket and have tried repeatedly to tighten the bottom cover without success. Am reluctant to move the govenor unless it is necessary. Can one approach the filter head by removing the oil pump?If you folks will walk me through this I surely will be grateful. Thanks and God Bless
Clooney
06-19-2003 03:31:43
 Re: Oil filter on JD B in reply to Joe M, 06-18-2003 20:24:34
third party image
Joe, removing the oil pump won't gain you anything. The filter body & filter head are in a different place than the pump.
~Your best bet is to pull the crankcase cover, drain the oil & stick a light way down in the crankcase. Then you will have to figure out if you will be able to work under the crankshaft & rods to access that filter head. ~All the oil lines will have to be removed from the filter head. Then # 7 will have to pulled down & out the bottom [an old 5 gal pail handle with the wire handle re-bent a little will usually work by inserting it in the side holes in #7 then swatting down on the wire handle with a hammer or piece of pipe], then bolts #5 will have to be removed.
~It is awfully hard to work under that crankshaft & rods & pulling the governor will help to see down in there. I find it much easier to work if the R/H rod is pulled loose from the crank & the piston/rod pushed forward.
~It�s a dirty job & will leave your hands & arms cut up but CAN BE DONE without pulling the governor. ~Using short cut down wrenches helps & being about 16 years old & ambidextrous is also a big asset.
~Go slow, ask questions & remove what you have to so you can see & work in that crankcase.
Joe M
06-21-2003 10:47:02
 Re: Re: Oil filter on JD B in reply to Clooney , 06-19-2003 03:31:43
Mr. Clooney Here I am again. Got all the oil lines disconnected from the filter head, the filter outlet out and the two bolts holding the filter head out. The head is stuck to the body pretty firm (its been there for 58 yr.) and I'm leary of beating on it too much. Need a bit of advice.
You folks were so right when you said this would be a dirty, nasty job. It probably would help if one was 16 and ambidextrous--this I know -being 80 and having short arms is not to my advantage. Still think that working on an old JD is great sport. Thanks and God Bless
