Hey Budd, I used to pull JD's a little years ago and love the topic so have a bit more to add. First, if you're at near stock compression (which is low on that tractor) and you're not runing at any super fast RPM or using any exotic fuels or have a performance cam, simply further and further advancing the timing is no cure all or winner. It's when youre at high compressions requiring higher octane fuels (which are harder to ignite) and at high RPM and maybe had some cam work done, when you need more spark advance. If you have access to a dyno, what I suggest is hook on and then adjust the run timing to achieve max HP. I suspect that somewhere between maybe 22 to 30 BTDC is where shes gonna peek out at assuming you have near stock compresion and fuel and cam etc. As far as mags, if the pullers run at high compression and therefore have to run higher octane fuel, they need a higher energy spark, and they buy the hot performance mags which have schedule 8 high magnetic strength rotors and hot coils. Again, its not so much incresed advance they are lookign for, its more spark energy necesary to jump a gap at those higher compressions. The usual ways to improve pulling pefrormace are upping the compresion with domed pistons, milling heads, or adding cubes via borign or stroking and THEN getting more spark energy. You also need to rid the tractor of horsepower robbers to whatever possible extent such as any hydraulics, generators, fans, water pumps, heavier than needed lubricants, air inlet and exhaust restrictions etc etc. Good fun topic you started. John T
