Deere 40-S Hunts Searches
Bill Childress
10-20-2003 11:23:51
Thanks to all for the help with my previous question, it was in fact the distributor was not grounded!
Now, I have it running and at low rpm it "hunts and searches" - rpm's vary greatly, sounds like a Briggs and Stratton that's out of adjustment. Is this normal, or can it be corrected? What causes this - I have adjusted the governor per the service manual and the problem persists. Thanks!
Clooney
10-20-2003 11:37:24
 Re: Deere 40-S Hunts Searches in reply to Bill Childress, 10-20-2003 11:23:51
Bill, it could either be the governor or the carb�.
~First thing to try is pulling the choke partially back on to see if that makes a difference�. If so you have a carb problem, either with the idle needle adjustment or internal passage blockage, or leaking carb throttle shaft bushings..
~If the choke doesn't help, try disconnecting the linkage at the carb & see if you can get the engine to settle down to a decent stabile idle if you work the carb lever by hand. If working the carb lever by hand gets you a good stabile idle then your problem is probably internal to the governor or the external governor spring is missing or hooked up wrong..
[email protected]
Mark
10-20-2003 11:36:16
Probably need to remove the carb and have it cleaned, also check your aircleaner for excessive dirt, water, ect. I just purchased one that hadn't run in several years,cleaned the carb and tuned it up, and it will sit there and purr.
Wayne in Tn.
10-20-2003 12:30:16
 Re: Re: Deere 40-S Hunts Searches in reply to Mark, 10-20-2003 11:36:16
Bill, I have seen this problem on several Dubuques. So far, not even one had a govenor problem. Those just don,t give much trouble unless something breaks in them. Most of the time, it is the carbureator. The usual culprit is the main nozzle. With the carb. apart, this is the brass tube that sticks up in the throat of the carb. It has to be removed and it has several tiny holes that run the length of it, these must be open in order to have a smooth idle. It is removed from the bottom of the carb, under the load needle. If it has not been out in a while, it may take some heat to the body of the carb. in order to remove it. They can be a pain to get out sometimes. If you have to destroy it or drill it out...new ones are about $25 from Roberts or any of the carb. dealers. Also make sure the tiny passages in the barrell are open.
