425 AWS starting problems
John
06-18-2003 06:53:14
My 425 is hard to start intermittantly. Found that it has no spark when this is happening. Cleaned and checked all the switches, battery terminals, etc. Once it starts it will usually keep running. It's an intermittant spark problem.
Does anyone have any ideas? Ignition module?TIA
Steve - IN
06-18-2003 09:50:59
 Re: 425 AWS starting problems in reply to John, 06-18-2003 06:53:14
John,
The ignitor module is probably a good place to start. I replaced that and the fuel cutoff solenoid in my 425 AWS last month, and it seems to have cured the problems I was having - started easy but sputtered and died when hot.
I found a shop manual for the 425's 620D engine on the web at>Link
good luck with it....
John
06-18-2003 10:56:24
 Re: Re: 425 AWS starting problems in reply to Steve - IN, 06-18-2003 09:50:59
Thanks Steve, I have the manuals and I guess I need to dig into it. Since it's intermittant, that makes troubleshooting it a lot harder. How much was that module?
Steve - IN
06-18-2003 14:28:18
 Re: Re: Re: 425 AWS starting problems in reply to John, 06-18-2003 10:56:24
John,
Memory says the ignitor part was the 49 or 59 dollar flavor from the JD dealer - can't find my receipt - and I bought a bunch of stuff for all 3 JD's that day.
In hindsight, I should have checked the Toro dealer or even a Kawasaki dealer, as that same engine is probably used in Jet Skis or 4 wheelers and maybe their markup isn't as large as JD's.
You're right about troubleshooting. Even the manuals have a lot of places that just say stuff like "replace with known good part".
John
08-14-2003 05:36:34
 Re: Re: Re: Re: 425 AWS starting problems in reply to Steve - IN, 06-18-2003 14:28:18
The problem with my 425 AWS was the ignition delay module, found out it is a common failure in this model. $16.00 and I was back running
