A Crankshaft
HERB
06-17-2003 11:54:43
I would like to know the NEW min and max clearence
between the main bearings and the crankshaft? This
is on a 1952 JD"A"
Earl S
06-17-2003 12:24:46
 Re: A Crankshaft in reply to HERB, 06-17-2003 11:54:43
Main Brg. clearance Spec. .004--.006
HERB
06-17-2003 13:01:37
 Re: Re: A Crankshaft in reply to Earl S, 06-17-2003 12:24:46
I want to make sure this .004-.006 is the NEW clearence not the acceptable worn clearence.
I mean NEW as out of the factory NEW!! THANKS
Earl S.
06-17-2003 13:18:56
 Re: Re: Re: A Crankshaft in reply to HERB, 06-17-2003 13:01:37
Herb, I am trying to help you . This is new spec out of the Federal Mogul brg manual .Federal Mogul And Clevite made all the brgs. for John Deere . If in doubt(of clearance) check with your local John Deere dealer.John Deere 2cyl can run a lot of clearance due to fact they have high volume oiling system.More people get in trouble trying to set a 2cyl up tight.Have a good day. Earl
HERB
06-17-2003 13:24:26
 Re: Re: Re: Re: A Crankshaft in reply to Earl S., 06-17-2003 13:18:56
EARL, Thank you for your help-I was just making sure. Thanks again--Herb
