General question on 3 point hookups
ChadR
06-16-2003 08:46:47
I notice that John Deere, Bush Hog, Servis, Rhino etc...use a single bolt stationary for the 3rd arm to ride on. ~ on their mounted and semi-mounted 10 ft rotary cutters. I bought this Howse junker to repair, busted input shaft. Looks to me like the reason it broke is a slotted or free riding 3rd arm...when you raise it up IF you have it set where it will slide back and forth at the 3rd point ---then the thing comes forward and brings the implement into the back tires ~ crimping the whole set up and somethings got to give ---so bang there goes the powershaft. I am going to redesign so that 3rd arm is stable. Any thoughts or similar experiences?
Clooney
06-17-2003 03:15:00
 Re: general question on 3 point hookups in reply to ChadR, 06-16-2003 08:46:47
ChadR, use a ridged upper link but install 2 pieces of strap steel about 3" between hole centers between the rear of the link & the cutter's upper link attaching point. That will allow the cutter to move around & even kick up a little when you go through a hole or swell but not kick up any more than the 6" of strap travel. Been using that setup for years & it works great.
~Don't use a chain as the will allow the cutter to flip over onto the rear tires & there isn't enough room on that tractor seat for both you & the tail wheel of that cutter...
Scruffy
06-16-2003 14:08:35
Having used a Howse mower alot I don't think the slotted toplink hookup could have busted the input shaft. It's more likely the two piece floating driveshaft is locked together, sticky, or has a tight spot. As the mower pivots back and forth the driveshaft is supposed to shorten and lengthen. If the shaft hasn't been greased atleast yearly it could get grabby or seize all together and do some damage. Or the shaft could have had something drop on it and put a bend it it to keep if from sliding freely.
Check and make sure the drive shaft moves in and out freely without any tight spots. I had an over run clutch on the PTO of one tractor be destroyed by a sticky driveshaft on a mower. A little grease once a year makes a big difference.
I've extensively use a Howse 6ft 3 pt mower for 4 years now (average 4 hours a week) and have never had a problem with it. But I also take my drive shaft apart every spring and put some fresh wheel bearing grease on it.
Thanks,
Scruffy
ChuckW
06-16-2003 10:16:04
seems to me that a chain from the mower to the top pin would be you best solution...wouldn't matter if the frame is rigid or not.
HA in Oh
06-16-2003 11:58:45
 Re: Re: general question on 3 point hookups in reply to ChuckW, 06-16-2003 10:16:04
I used to use a 6ft 3pt, I always used a chian for a top link, only way to go on uneven ground.
JDknut
06-16-2003 16:58:17
 Re: Re: Re: general question on 3 point hookups in reply to HA in Oh, 06-16-2003 11:58:45
I have heard that the chain on top instead of the link is unsafe, because if the mower hits an obstruction, it could pivot up and hit the operator. I saw this in an article on this site about "brush" hog safety. I
I'd use the top link rather than a chain. just my $0.02.
