Aluminium Pistons in a 38 AR?
Andrew
06-15-2003 23:02:15
Hello,
I�m restoring a 1938 AR which requires reboring from standard to 45 thous oversize to remove a score, rust pitting and a ridge. What is involved with fitting new oversize aluminium pistons to it? From what I�ve worked out the replacement pistons available are for later models with larger piston pins, higher compression ratios etc. Would it still run much the same? Are there any other options available? It seemed to be a much cheaper, easier way to go than to try a stick with the original cast iron pistons. Any help, opinions would be much appreciated. Thanks Andrew
Sydney, Australia
ChuckW
06-16-2003 10:13:55
 Re: Aluminium Pistons in a 38 AR? in reply to Andrew, 06-15-2003 23:02:15
I prefer the original pistons...you should be able to find a pair 45 over. Most of them will have very little wear...you can fit aluminum but the machine shop should allow for more clearance, higher/faster piston growth.
Andrew
06-17-2003 05:25:02
 Re: Re: Aluminium Pistons in a 38 AR? in reply to ChuckW, 06-16-2003 10:13:55
Thanks Chuck,
Yes I agree. I would prefer to have cast iron pistons in it for originality. I think I feel I would be "modernising" it by changing it to aluminium. Trouble is finding oversize pistons here without going to great expense.
Thanks for your time.
Andrew
