48A Carb
earle jennings
06-15-2003 04:11:33
what is the correct Carb for this model A or what carb is possible to use on it
John T
06-15-2003 07:29:33
 Re: 48A Carb in reply to earle jennings, 06-15-2003 04:11:33
Earle, according to the literature I have, the original carb was a Marvel-Schebler DLTX-71 for a Gas Only tractor (NOT the hot mainfold duel fuel gas/distillate tractors) and a DLTX-72 if it were an All Fuel (Hot manifold, dual gas and distillate tanks). If youre just using gasoline, not any distilates or kerosene etc., you could probably get by with most any of the A carbs such as DLTX 71, DLTX -72, DLTX 53 (but its for older A's).
The AR and AO carbs, DLTX 19 or DLTX 41 might work, but the DLTX 71 or 72 would be my choices.
Good luck. John T. Nordhoff
