Chuck, your problem could be almost anything in the steering hydraulic part of the system. ~The most likely place is in the steering sleeve area [possibly a loose, worn, or missing pin, or worn cam, or excess end play]. ~You might want to start with a steering vane leakage test [both directions], that will eliminate a lower vane leakage problem. BUT, I don't think you problem is in the vane area though as it steers better when you hold the steering shaft forward. ~My suggestion would be to get the Deere steering repair manual & work your way thorough all the test & check procedures. ~We could probably get you a little closer to the cause if we knew the history of the problem & when it last worked correctly & how it acted as the problem became more pronounced. ~You might try increasing the flow rate by adjusting the flow control valve,,, if that helps your problem suspect a cam problem, or one of the pins has worn a notch in the side of the cam slot, or there is a notch worn in the sleeve at a pin interface. [does it steer better to the problem side when on a slick surface with little front tire traction & get worse when the front tires are on pavement?]. When you hold the steering shaft forward that could be helping a pin slide by a worn spot in a sleeve slot. ~Because you have a 720D we really don't know if you have the early or late steering sleeve in it [makes a difference in the problem area & how to adjust it] . There is a S/N break, but because of the age of the tractor in a lot of cases there has been some parts interchanged over the years. If it has a helix set screw it's an early system,,,if it has an end play adjusting bushing on the front of the worm it has the late system.. ~If you can furnish a little more information on the history of the problem we might be able to point you down the correct path to finding the root cause without a complete system disassembly�
~About all I can tell you is more than likely the problem is in the steering sleeve, or cam on the rear of the sleeve, & in most cases it is wear on the pressed in pins or the slots the pins run in.
