4020 question
Sid
06-13-2003 23:04:37
I have heard people talking about heads on other makes of tractors with freeze plugs in them. I know a guy having water in the oil on his 4020. Does this desiel engine have freeze plugs in the head? I do not want to suggest this unless I am fairly sure that it has them.
JD 4020 G
06-14-2003 14:47:08
 Re: 4020 question in reply to Sid, 06-13-2003 23:04:37
Yes 4020 heads have anexpansion (freeze) plug, one of them. Water in the oil is not from a freeze plug. It's from the head gasket or cylinder liner O rings. The older 4020s made from 1964 to 1968 have weep holes in the block at each cylinder. If the O rings are bad the water will come out of the weep holes with the bad O ring. If the 4020 was made from 1969 to 1972. it does not have weep holes. If the engine is one with weep holes, and if the weep holes are clean and open, and water is not coming out of them. The engine has a bad head gasket, or the cylinder liners (sleeves) have holes in them.
Jim B
06-14-2003 04:14:32
Sid,I don't remember seeing any freeze plugs in 4020 head.Water is propably from o-rings on bottom of liners leaking or head gasketJim B
Sid
06-15-2003 13:03:43
 Re: Re: 4020 question in reply to Jim B, 06-14-2003 04:14:32
Thanks guys.
